Create Scene splk file takes forever
866
05-25-2017 07:58 AM
simontransits2
I have a multipatch layer imported from collada mesh in a file geodatabase. The database is about 2.2GB
When using the Create Scene layer command to create a slpk file, I let it run 16 hours and it still not finished.
The CPU is about 40-50% all the time and the drive space increase about 100mb after every few hours. I guess thats the cache.
If I subset some part of it, the slpk file gets generated. I worried as utimately the db will be 50 times over due to increase coverage. If anyone work to produce a few gigs size of a single slpk file, hope you can share your experiences.
My hardware is a i5 with 16gb Ram and GTX960. Arcgis Pro 1.4
