Create Polygon By drawing 1 line connecting existing Polygons.
1787
01-27-2025 08:30 AM
FlightDeck
Hey All,
Hopefully a basic question, But how can I draw 1 line between multiple existing polygons to create a new polygon where no polygon previously existed.
Example attached to hopefully clarify. In the drawing the red polygons 1, 2 and 3 exist. I want to draw in the blue line to create polygon number 4 with all of the same fields and on the same layer as 1, 2, and 3. What is the process to accomplish this?
DavidPike
MVP Notable Contributor
FlightDeck
Thanks David,
I don't think this will work in the use case I have as I don't see where it shows how I would draw the blue line to complete the missing boundary. Am I missing something?
DavidPike
Ah yes apologies.
The auto complete polygon tool on the Create editing template should work for most use-cases.  if you do end up with so extra multipart polygons you can easily delete them out.
  https://pro.arcgis.com/en/pro-app/3.4/help/editing/create-adjoining-polygons.htm#GUID-BDD43E74-B118-...
