Create legend with 3D point extrusion
2368
05-30-2018 04:40 PM
mikelevine
I have a ArcGIS Pro Scene in which I use an extrusion of point data to display my value of interest (biomass) geographically. The base height of each point is sized by biomass and I have a 3D representation of biomass that looks fine.
I am looking to create a legend in an ArcPRO Layout in which a single bar is scaled to indicate the median height of points (i.e. median biomass). In ArcMap 10.xx, I did this by plotting each point as a bar chart, and the legend automatically handled creating a single scaled bar. I'm hoping to recreate that in a ArcGIS Pro 3D scene. Thanks,
Mike
DanPatterson_Retired
so you are using this process http://pro.arcgis.com/en/pro-app/help/mapping/layer-properties/extrude-features-to-3d-symbology.htm
but can you show what you mean since not all is the same or in the same place if it is
mikelevine
Yep, I'm using the process you linked to- all works fine there. I used the "Extrude points" function to represent the variability in biomass, using 'Base Height' Type. The only problem is in adding a Legend, in the Layout view. It is simply adding a small hollow vertical column icon for the extruded points.
Here's a segment of a ArcMap 2D representation, with legend (in blue dashes) as a scaled bar.
I'd love to recreate this legend type, but using 3d Extrusion.
Thanks!
ShelbyConnors
Dan Patterson‌ would you be able to follow up on this question?
busy trying to get a workable Pro 2.2 clone environment... if you have been following the panic around you before UC
