Create field from symbology class values
2025
10-13-2021 02:13 AM
saidurgamalleswarthota
Hi all,
I used graduated colours and standard deviation for the symbology of my layer. All the field values were divided into 7 classes.
Similarly, I have the same layer with a different field. So again it's divided into seven class values in the symbology by graduated colours and standard deviation.
I want to compare the features that fall into the same class value of symbology. If I can create a field from the symbology classification then  I do the matching of the same class or rank for both the fields. Please help me to do this.
How to create a field of classes that the features belong to?
KoryKramer
Esri Community Moderator
Instead of thinking about it from the symbology point of view, you could use the Reclassify Field tool to add a field - it has a Standard Deviation reclassification method so it sounds like it will allow you to do what you want.
Hope that helps.
KoryKramer
Hope that helps.
Thank you for helping. It worked as I wanted.
