Create an independent map on ArcGIS Pro from layers in a ArcGIS Online map
1083
11-08-2021 03:02 AM
LoriannChevalier
Hi everybody,
I created a map with blank layers (point layers) in ArcGIS Pro. I saved it as an online map and opened it in ArcGIS Online, and further collected data via ArcGIS Collector. Now I have my map and layers filled with points in ArcGIS Online. What I want to do is create a map (or shapefiles) which I can open and modify in ArcGIS Pro without connection to Online (i.e. an independent map from the online one, so that when I modify this map in Pro, it does not modify the Online one). I tried to use Map > Offline > Download Map but it did not work (nothing happens).
Does someone know how to create an offline map from ArcGIS Online to ArcGIS pro.
Thanks a lot!
Gisbert61
I would open PRO, load the online map and use the "feature class to feature class" conversion tool to make a local copy
Gisbert61
