Create a single line from a point using the attributes of that point
6232
04-25-2022 07:54 AM
LarisaJohnstone
Does anyone know if it is possible to create a line feature from a point using an angle and distance field defined in that point attribute data?
Basically I want a line to be drawn from the point at a specified distance and angle. The end resultant line can have the point as a centre point starting point or end point, it does not matter. Also, I have thousands of points to do this too...they all have the same length, but various angles.
Larisa
DanLee
by Esri Regular Contributor
RobertBorchert
Honored Contributor
Actually pretty simple.  Use SOH CAH TOA  to determine the O and A and add them to the original X,Y
The generate your lines from the table
DanLee
LarisaJohnstone
Thank you DanLee
This worked perfectly. I was not aware of this tool. Thank you for educating me!
Larisa
DanLee
You are welcome. Glad it worked for you.  🙂
