Copy and Paste Button in between Dialog Boxes Question ?
577
07-08-2025 10:26 AM
DEAF_PROBERT_68
Honored Contributor
So I am experiment and write a step by step for a co-worker and here I have a problem with layer that has the wrong projection....
So, basically what I am trying to do here is to a copy and paste the gegoraphic coordinates
Look at the screenshot ...
Open the Layer's Properties
Click on the source and to the far right there is a Copy button that you want to copy the extent of the geographic coordinates
Closed the Layer Properties
Then go back to the layer and right click to  Export the Data Features
At the top of the Export Features.
Double Click on the Environments
Go down to the Processing Extent .
Click on the Copy/Paste Button and then choose "Paste Extent"
So what I see here is it did not copy and paste to this
Hmmmmmm.....  So my question is Why did it not copy and then paste into the X and Y ?
I am using ArcGIS Pro 3.3.6 and Has it been update to correct this problem to the new version 3.5 ?
Thanks !
DEAF_PROBERT_68
Honored Contributor
Hey I have not heard anything from you guys ? And oh They are at ESRI UC !!!! ha ha
