Converting Labels to Graphics
1012
01-07-2025 12:39 PM
MattCarocci
When you convert labels to graphics, where within your project are the new graphics saved? I asked because I pull AGOL webmaps into Pro to make changes, so I often need to update my Pro Project that correlates to the webmap, which deletes the graphics. I put a lot of time into these custom labels. It would be nice to not lose them...but also not having to export them, update my project, then import them. Thanks!
Tags (3)
DavidSolari
MVP Regular Contributor
Graphics are stored as a layer in the map they belong to. Well, specifically they're stored in a separate file inside the project file that the layer refers to, but that's just for performance reasons. If you right-click on the layer you can use Sharing -> Save As Layer File to keep a copy stashed away, hopefully that's enough to save what you need.
