Converting Feature Class to Shapefile Issues
2719
04-22-2022 12:09 PM
Labels (2)
KrishnaTiwari
Hello Everyone,
My name is Krishna Tiwari and I'm currently trying to convert a feature class to a shapefile. When I convert the feature class to a shapefile, the field names in the attribute table are changed. For example, the newly created shapefile will have "Zip_Co" instead of "Zip_Code" as the field name in the attribute table. Has anyone come across this problem before? Any help would be greatly appreciated!
Sincerely,
Krishna Tiwari
Sean_Wray
https://pro.arcgis.com/en/pro-app/2.8/tool-reference/tool-errors-and-warnings/001001-010000/tool-err....
Field name are limited to 10 characters is SHP files. If you use the GDB format this limitation will go away.
KrishnaTiwari
Thank you Sean_Wray!
DanPatterson
KrishnaTiwari
Thank you DanPatterson!
