Converting CAD solids as closed MultiPatches
1088
11-03-2022 07:16 AM
OfirMazor
I have DWG files with solids geometries.
When I'm using CAD to GeoDatabase on arcpro (2.9), some of the solids converted as closed multipatches and some as open multipatches .
I know I can use the Enclose Multipatch tool but it's results are not good enough.
I also don't understand if the problem is on the DWG drawing  or in the conversion to gdb feature classes.
how can I validate that the solids in the dwg will be closed multipatch before I convert to feature classes?
Tags (3)
