Converting 2D features into a 3D web environment?
1980
12-28-2020 03:09 PM
BarrettLewis
Hi all. I'm partaking in a research project where I was given a 2D building floor plan (itself in geodatabase), with the intention that I visualize it in a 3D web environment. I'm fielding suggestions for how I might do this, either using ESRI software or otherwise? I was on a promising path with ESRI Space Planner before my contacts in the organization I'm doing this project with told me they couldn't go down that route because they weren't using AutoCAD files. Any suggestions would be fantastic, thank you!
DanPatterson
MVP Esteemed Contributor
Don't know about the web side, but in its simplest form...
Extrude features to 3D symbology—ArcGIS Pro | Documentation
... sort of retired...
BarrettLewis
Hi Dan, thanks for the reply. Do you know why the Extrusion fields might be grayed out/inaccessible to me?
by Anonymous User
Not applicable
3D creation can be done in ArcGIS Pro and shared with AGOL, as AGOl can only consume 3D as a visualization tool.
DanPatterson
Select the layer in the map's table of contents because...
If more than one layer is selected in the Contents pane, extrusion choices will be disabled.
And you must have an appropriate numeric field for the extrusion values
