Convert a standalone table into a shapefile in ArcGisPro_ column headings are changed
925
04-29-2024 07:31 AM
cskari
Hi All
I created a 0.01 degree fishnet (GDA 2020) in ArcGisPro. I used this grid file to get the attribute tada of a vector file using the "Tabulate Intersection" tool and then the "Pivot Table" tool. I received a standalone table where the selected Pivot Field names are given as headings and the relevant cells of the table are filled with area values against FIDs. I used the 'add Join' tool to get lat long values from the 0.01 Grid file into this table. Then I  converted this Table into an events shapefile using "Display xy data". However, the column headings of the shapefile attribute table are different from the standalone table headings. How can I get the same headings into my shapefile attribute table? Thanks
