Control visibility of same features in different layouts and/or map frame
14289
10
09-21-2020 01:19 PM
CandiceOoi1
I am creating several maps in different layouts and different map frames using the same features in ArcGIS Pro. However, I would like to only show some features in one frame and not the other. When I toggle off the features in one map frame, they will disappear in other map frames and my map as well. Is there a way to make the visibility independent of each map frame?
I appreciate your advise in the best workflow in handling situations as such. Here is a thread that I came across on Stack Exchange.
Thank you so much!
AmySnelgrove1
I agree! The way it's set up, if you want symbology to be consistent across all maps and you change it in one, you now have to change it 10 times instead of once in a single map frame! I hope this is in the works.  it's a pain!
