Contingent Value Import - Range Domain error
448
12-01-2024 09:20 PM
RobHoughton
Currently running ArcPro v 3.2
When attempting to import contingent values list (using either the geoprocessing tool or the ribbon strip Import button) containing a 'Range' contingent value type, the program will either crash entirely or throw a file import error.
The value is being applied to a Short type field in an eGDB Feature Class which has a pre-defined Short type range domain and is within the existing Min-Max range of the domain (0-100)
Import formatting has been derived directly from export sheets produced from manually applying the desired range contingent value, e.g.:
CV_TYPE1CV_VALUE1DESCRIPTION1
458.000000#58.000000
