We're just getting started in our move to PRO. Is there a way (like ArcGIS ArcMap) in PRO, that the connection to our SDE databases is available ALL THE TIME? It seems live EVERY SINGLE TIME, we create an ArcPRO project (map?) we have to connect to the SDE databases residing on the server.
Pete
Yes there is a way for ArcGIS Pro to remember SDE connections. Build the connection once in the Catalog Pane->Databases. Right-click on the *.sde connection and choose "Add to New Projects." Voila - all new AGP projects have your *.sde connections added to them.
I don't see *.sde connection.
Where are you attempting to view *.sde connections?
You're welcome! If you consider my answer to be correct, please click "Accept as Solution" in my answer "box" to close out the thread. Thx!
