Connecting to a folder on a server in ArcGIS Pro
6940
11-13-2014 09:37 AM
JoshuaPuthran2
Hi everyone ,
I was hoping to find out about creating a connection to a folder on a server on ArcGIS Pro. The steps that I follow to create a folder connection in ArcGIS Pro are:
- Right click on folder connections -> Connect to folder.
- Within this category I am only able to create connections to a local drive and unable to see network drives locations to create connections.
I have not been able to find any information on this so far. Any help on how to go about achieving this would be highly appreciated.
MarkBockenhauer
You can create an ArcGIS Server connection to access services.
mark
BrianDudek
I am not sure he was asking about an ArcGIS server connection.  Likely a local network server.  The program does not allow me personally to see the local network connections when creating a new project  I can only place a project on a local hard drive.  However, if I put the direct address location into the box, it will place the project at that location.  That is the workaround it appears.
AsrujitSengupta
Yes, The Network Drives do not seem to show up in the list when we try to create a new Folder Connection in ArcGIS Pro. However, you directly add the Path to a Network Drive and that should work, as Brian suggested in the previous comment.
RayMangan2
Do you know if this will be addressed in a future update? It seems like core functionality that is missing.
