Conducting IDW interpolations from a single dataset
2222
10-10-2022 08:49 PM
alrachman42
Hi all,
I have a single CSV file that contains about 20 different measurement stations that each have its own (large) set of water quality data points. I'd like to find a way to do Inverse Distance Weighting (IDW) interpolation without having one station's points influence another's.
Is there a way to do this with one command (all at once)? Or would I need to create separate feature layers for each station?
Thanks in advance and please let me know if I can clarify anything!
DanPatterson
MVP Esteemed Contributor
Split By Attributes (Analysis)—ArcGIS Pro | Documentation will get you the 20 different layers.  Coding or batch IDW from there will finish the job
... sort of retired...
DanPatterson
alrachman42
Wow, this was so helpful. Thank you so much!
