Composite Bands Output Symbology Issue
916
09-08-2025 12:11 PM
Ed_
by MVP Regular Contributor
So in Pro 3.5.3, i have been trying to create composite band raster in GeoTIFF format. So, I used 5 rasters as input rasters all in GeoTIFF format. Please note that none of them are RGB or spectral bands. The output comes out black for some strange reason even though the pixels have values. I even tried rebuilding the pyramids but still the same black render on the map.
So, then, i extracted the input rasters in ESRI grid format to a geodatabase. and then ran the composite bands tool, and stored its output in the ESRI grid format as well  in geodatabase, then the output default output symbology comes out as expected.
Is the black render output a bug in Pro 3.5.3 with the GeoTIFF format output in the Composite Bands tool? Or is this a limitation when composite band output is stored as a GeoTIFF raster?
Question | Analyze | Visualize
DanPatterson
as per your previous thread
Composite Bands Output Issue - Esri Community
are all the rasters integer? with values in the range 0-255?
if they are and the esri raster works, or even a plain *.tif then it has something to do with the geotiff specification.
I don't see anything on the public facing support site, so contact Tech Support for further help
... sort of retired...
