Circle from 3D points of different altitude
1360
07-08-2021 01:38 AM
igemetristechnologies
Hello community,
I have 3 points with different altitudes and I would like to create a cirle connecting them. When I try using the create circle with 3 points the circle is taking the height of the first point and creates the circle horizontally. Is there a way to create a circle snapping on the 3 points with different altitudes?
Thanks for any help!
Ana
DanPatterson
ideally, the circle option from Minimum Bounding Geometry (Data Management)—ArcGIS Pro | Documentation
would be a great choice, but I suspect that they only support 2D coordinates
... sort of retired...
It created a polygon Z but the altitudes are all 0 😞
