Changing a shapefiles editing capabilities
2184
03-09-2022 07:18 AM
GaryMorris2
I recently took a new job and I have walked into a situation where there is no metadata for virtually anything created before I got here.  I am trying to add a "Description" in ArcCatalog for a shapefile I received from a contractor that was doing some work before I got here.  I do not have the option to add any, I understand that this is a permissions issue however, I do not know how to change the permissions to allow the editing of the "Description"  The features within the shapefile are editable.
DanPatterson
MVP Esteemed Contributor
related  Solved: Shapefile Description - Esri Community
try making sure the shapefile isn't open in a map or being used perhaps, otherwise check the file properties in Windows
... sort of retired...
GaryMorris2
It isn't opened anywhere, I even tried exporting it and adding it to a new file geodatabase and closing out everything and opening just catalog.  It still doesn't give me the option.
JayantaPoddar
What do you see when you right-click the shapefile > Edit Metadata?
Think Location
GaryMorris2
Robert_LeClair
Esri Esteemed Contributor
Gary - I only saw one internal customer call with this error message and it was resolved by removing the Target for ArcGIS extension from GeoSoft.  There's something about XML formats via that extension that causes the issue.  Test on a machine without this extension.  What is the result?
