Change separately CSV point symbols
1947
03-07-2022 07:16 AM
fred7
Hello,
I have CSV file with station names and coordinates. When I add them to ArcGIS Pro, they all have the same point symbols. How to change the symbol of two stations separately?
I have previously done this by splitting manually the CSV file and imported those separately but this is quite time consuming when I have a lot of files.
Thank you!
Tags (1)
2 Solutions
ASw93
If you go into the Symbology settings for the layer, you can change the symbology settings from Single Symbol to Unique Values. You can then assign a unique symbol to each value of station name for example.
KimberlyGarbade
If you converted  the CSV to a feature class you can double click your feature class' symbology in your table of contents.  This will open the Symbology Pane.
Symbolize on "Unique Value":
Then you can pick the field that contains the unique values you want to symbolize based upon.
ASw93
KimberlyGarbade
