Cannot retrieve properties error when I attempt to manage geodatabase functionality
1699
06-04-2025 10:00 AM
TonyDevita1
I am getting the error shown in the snip when I attempt to manage a particular feature dataset. None of the other feature datasets have this problem. I created a new feature layer for this dataset, which is why I need to re-version.
TonyDevita1
Nevermind, I was able to just run the Register as Versioned tool and fix the versioning. Sometimes I forget there's a tool for almost everything in ArcGIS.
TonyDevita1
I forgot to mention that I'm using 3.4.0.
Robert_LeClair
Esri Esteemed Contributor
By chance, is Editor Tracking enabled on the FDS?  If so, disable it and try your workflow again.  Does the error message persist?
TonyDevita1
