Cannot create new python environment in ArcGIS Pro 2.2
22870
24
07-03-2018 12:13 AM
ChrisHills
I have updated ArcGIS Pro to 2.2, and now I am unable to create a new python environment. I have tried both cloning the default, and creating a new one. It creates a new directory in the %USERPROFILE%\AppData\Local\ESRI\conda\envs folder, but after I click on Ok, it disappears, and even after restarting ArcGIS Pro only the default python environment is available.
DanPatterson_Retired
For those following a simpler solution
https://community.esri.com/ideas/15429
HughGraham
I Was having issues with this - Couldn't clone the defualy ArcPro Python environment so I used Conda outside out ArcPro to fix the issue.
I opened the default conda environment > opening this batch file:
C:\Program Files\ArcGIS\Pro\bin\Python\Scripts\proenv.bat
Then cloned the environment:
conda create --name arcpro_clone --clone arcgispro-py3
activate arcpro_clone
The environment was installed in:
C:\Users\<user>\AppData\Local\ESRI\conda\envs\arcpro_clone
following this it was possible to edit the environment with Conda directly
Set up a batch(.bat) to open this env more effeciently in future with:
@echo off
set PATH=%PATH%;C:\Users\<user>\AppData\Local\ESRI\conda\envs\arcpro_clone\Scripts
%windir%\system32\cmd.exe "/K" C:\Users\<user>\AppData\Local\ESRI\conda\envs\arcpro_clone\Scripts\activate.bat arcpro_clone
Cheers
MichaelThro
I'm having the same problem, with the message that the environment "doesn't contain NumPy, which is required for ArcGIS Pro." The problem is that I am in a restrictive environment because of government computer rules, so I can't try Hugh Graham's suggestion above (can't use a batch file). It's been awhile since this question was originally posed - does ESRI have a fix, or is it just to install the latest ArcGIS Pro version?
Thanks.
DanPatterson
MVP Esteemed Contributor
ArcGIS Pro requires numpy, so just install the latest version
... sort of retired...
