Can you solve this?
2315
02-20-2017 03:09 PM
Jean-SimonLevert
I have
x :  -73,512864
and
y:  45,659871
What is the code i need to put in ArcGIS Pro (Python3) to go to that GPS place and to zoom it at 1:5 000?
Put your codes lines here  (I tried everything and im not able to find any way.)
DarrenWiens2
If you've tried everything, how can we help?
Share your best guess and we can go from there.
DanPatterson_Retired
I think there is a need for code... previous link
RebeccaStrauch__GISP
Looks like you can use the Locate tool to get you there. Look at this thread Is there a Go to X Y tool, or similar in ArcGIS Pro ?
Zooming to 1:5000 I'm not sure
edit: for the python side of things, this may be a good starting place
Add Locations—ArcGIS Pro | ArcGIS Desktop
Jean-SimonLevert
import arcpy
aprx = arcpy.mp.ArcGISProject("CURRENT")
m = aprx.listMaps()[0]
lyr = m.listLayers()[0]
lyt = aprx.listLayouts()[0]
mf = lyt.listElements()[0]
mf.camera.setExtent(mf.getLayerExtent(lyr, False, True))
I found that this will zoom out until i see everything.
Im still looking for a way to get to x : -73,512864 and y: 45,659871 and to zoom to 1:5 000.
This seems to be a duplicate post??
See Joshua Bixby‌ response https://community.esri.com/message/668014-re-zoom-in-at-15-000-at-x-73512864-and-y-45659871
Also, I'm not sure how to set in Pro, but make sure it knows your separator is a "," comma and not a "." dot  (localization?)
