Can you add unique text boxes to different map series layout pages?
1139
11-17-2025 12:31 PM
Aidan_Williams_SFRPD
I'm making a map series in ArcGIS Pro, but I want to add unique text boxes to each page. The text are callout boxes that contain specific notes for different map features.
I don't want to automate this. I just want to be able to add different text boxes to each map page, however, the map series duplicates text boxes across each page in the series.
Is there a way around this?
Thank you!
Eugene_Adkins
You can. Add the text box/map note to the map itself instead of the layout, and each “page” in the map series will contain/display the created text box along with the corresponding features contained in the map series page.
Eugene_Adkins
Ah of course. Thank you!
KeithAddison1
Is there any way to just tell it to turn off certain text items for certain sheet.  Cluttering up the map isn't a good solution when you need to show multiple views of the same areas but don't need the text element in all of them.
