Can't use graduated colors because "field does not contain quantitative data"
4690
06-18-2019 11:43 PM
remisap
In a layer I have 100 features with a counter attribute of type Long. The values range from 3 to 10000. I'd like to create a graduated color symbology but I'm stuck with this error message.
This field does not contain quantitative data to generate symbology.
A temporary symbol class has been created.
What's happening  ?
Thanks.
DanPatterson_Retired
Add a new field of type 'double', call it something (eg 'New_class')
Calculate the new field using the values from the old field (eg 'Count_fld')
use the python parser, so that...  !New_class! = float(!Count_fld!)
remisap
FYI, when a query use the view_extent parameter, the query must complete when the parameter is null, otherwise he query to discover the range of possible values fails which results in this error message.
DanPatterson
What is in your field? numbers? text that looks like numbers?  Null values are handled by symbology regardless of data type
... sort of retired...
remisap
Hi Dan, the query had indicators of type integer, bigint and double.
After handling the case when view_extent is null, the distribution of values appeared and graduated colors worked !
