I am trying to calculate a field in ArcGIS PRO. The field should contain a constant in every row. This constant will be equal to the maximum of another column in the table.dbf WFr_100.
I can get to the number with this code, but I would like to do it through the field calculator inside Arcgis PRO. Is there a way to do that?
# Import system modules
import arcpy
import numpy
# Set environment settings
arcpy.env.workspace = r"C:\Users\MD \Documents\ArcGIS\Projects\IP\Default.gdb"
input = "WFr_100" arr = arcpy.da.TableToNumPyArray(input, ('CMass'))
x=(arr["CMass"].max())
print(x)
Do the work outside and bring it back in.
Close Pro to make sure any file locks are gone.
Verbose example
from arcpy.da import TableToNumPyArray, ExtendTable
tbl = r"C:\arcpro_npg\npg\Project_npg\npgeom.gdb\sample_10k" # my table
arr = TableToNumPyArray(tbl, ["OID@", "Age"]) # the objectid field and another
arr1 = arr["OID@"] # make oid values
arr2 = arr["Age"] # Get the values you are interested
count = arr2.shape[0] # get the length of the array
mx = np.nanmax(arr2) # ---- now get the max... nanmax accounts for nulls
vals = np.repeat(mx, count) # ---- repeat the maximum "count" times
# create output ---- excitement builds
z = np.empty_like(arr) # build the output array
z.dtype.names = ("OID@", 'Max_Vals') # make your output names
z["OID@"] = arr1 # put the id values in
z['Max_Vals'] = vals # put the max in
ExtendTable(tbl, "OID@", z, "OID@") # magic-orama ... like a joinNow open Pro and open the table to see the results.
I have helper functions that expedite this, but you need to understand the procedure first.
numpy is extremely powerful and I have numerous blogs on its use with arcpy in the Python Blogs... look for me and me before retirement.
Verbose example
Spot on, Dan! Thank you.
