calculation within an IF statement in arcGIS Pro
5335
12
08-10-2018 08:24 AM
MáireDolan
I'll begin by stating I am very new to the python world!
My problem is this....
I am trying to use field calculator in ArcGIS Pro to return a calculation of values in other fields based on an if statement, if that makes sense! Not sure if it can be done?
The Calculation is
Qrp=Sum(Qs*Ls)/SumLs
Basically thus;
weightAADT(!rp!,!Qs!,!Ls!)
Code Block
def weightAADT(rp, Qs, Ls):
       if rp=="Urban Two Lane":
            return sum(Qs * Ls) / sum(Ls)
my error is "TypeError: 'float' object is not iterable"
Any help appreciated
MáireDolan
Fair enough Dan,  I'll try and explain...
I have a database with 525 entries, which I will call 'sites'. Each site has a 'RP' field with 1 of 4 possible attributes, i.e. Urban Two Lane, Rural Two Lane etc.
I need to carry out a calculation, based on the RP attribute, that returns the sum of [Length of site (Ls) * Traffic Flow @ site (Qs)] divided by sum Ls.
So a calculation needs to be applied to each site belonging to a defined RP, before summing up for that RP, if that makes sense.
Below is a very simplified version of fields and attributes contained in said database
Site_IDLsQsRP
R1251.254445Urban Two Lane
R1480.988956Rural Two Lane
R5241.352350Urban Two Lane
R3850.8810253Urban Dual Carriageway
R4491.0115236Rural Dual Carriageway
R6211.11052Urban Two Lane
To be fair Dan I have used the summarise feature followed by a join to get the required result, my query was if there was a better way of doing it in Pro with field calculator alone.
DanPatterson_Retired
better way... no... only way... yes …. well, except for doing it in numpy from the start and producing the summary result table directly, but that would be a parallel solution
MáireDolan
Thanks Dan
