Calculating statistics on a feature with variable parameters
1090
12-03-2020 03:01 PM
SergioMaia
Hi:
Think of a dissolved buffer feature created from a XY point feature with Radius R centered in each point. T
One the required parameters  is the distance R (Radius) from the point feature. ArcGIS creates the buffer and end of story.
However,. I'm not particularly interested in the buffer other than its area and population as a function of R.
The objective is to create a table of population density averages for various values of R (for example, (0, 10) miles with 1 mile steps.
I know how to do this by creating the actual buffer with a defined R and then, calculate averages using the summary tool. However, this is unworkable for variable R.
Is there a way to do this?
Thanks a million!
Sergio.
DanPatterson
MVP Esteemed Contributor
If your distance bands are finite, then
Multiple Ring Buffer (Analysis)—ArcGIS Pro | Documentation
may be what may be useful
... sort of retired...
