Calculate Geometry Attributes ArcPro 2.2
9455
20
06-28-2018 07:52 AM
AileenProfir
I'm trying to use the  'Calculate Geometry' tool (selected by right-clicking a field in the attribute table) to calculate XY coordinates for a point and have also tried to calculate square miles for a polygon feature. I am getting a "RuntimeError: Objects in this class cannot be updated outside an edit session".  It was my understanding that edit sessions are automatic in ArcPro.  How would I go about starting an edit session?
Thanks for your help,
Aileen
ThomasColson
I'm not seeing that...how did you get to 2.2? Upgrade, or clean install? (Guess what tech support is going to ask you to do....). What is the source of the data, FGDB, SDE, Shapefile, Feature Service, Offline Feature Service in SQLite Mobile Geodatabase? What options do you have set here:
AileenProfir
Yeah, it was just the standard upgrade to 2.2.  I do have the checkbox for newly added layers editable by default checked off.  It is in SDE, which I thought might be the issue at first, but I can still make all kinds of other edits without an issue (update attributes, move, merge etc.).  This is the error message...
Error Message
Aileen
ThomasColson
Is the SDE feature class versioned, are you direct editing against the SDE? If it is versioned, what version are you editing?
AileenProfir
Editing directly to the default SDE...
ThomasColson
Well, belay that. I get the same error on versioned and un-versioned SDE feature classes, and just on calculate geometry. I can make all other field calculations. Another thing I missed during Beta....
Seems like a bug...
AileenProfir
Well, I'm glad it's not just my imagination 😃
Thanks!
ThomasColson
I'll see if any one else on GN can confirm the behavior, then log a case next week, unless you want to, but do keep the thread posted so TS isn't getting the same call twice.
DrewFlater
Aileen ProfirThomas Colson‌ what type of enterprise gdb are you using? We've tested in house on SQL Server and Postres, using unversioned feature classes, and it's working here. Thanks
EDIT: Tested Oracle too, and found it working. Any details about the repro steps can get us started on fixing this for the first 2.2 patch. Thanks
AileenProfir
Probably not what you want to hear...but, we are using SQL Server (2016 version, I think).
