calculate field
1780
02-15-2024 04:17 AM
itayroei
Hi dear community.
I need to accumalate value of one field by order of other field.
I sucsses to accumlate value but the order detaramine by "OBJECTID"
who can i change that?
thanks
itay
PedroCoutinhoMendonça
Hello Itay! You can use update cursor in python do achieve what you want. In the sql_clause parameter there is one exemple of the epression used with ORDER BY
https://pro.arcgis.com/en/pro-app/3.1/arcpy/data-access/updatecursor-class.htm
with arcpy.da.UpdateCursor(
        in_features,
        ['OID@', "ELEVATION"],
        sql_clause=("TOP 5", "ORDER BY ELEVATION DESC")
) as cur:
itayroei
thank you pedro
i will try your solution
hopes that it's work for me
best regards
itay
Amir-Sarrafzadeh-Arasi
Dear itayroei,
I hope you are doing well,
If you are using ArcGIS Pro, you can do by this way, insert a New Notebook,
and write the python script like below image,
Here I read the Airports feature layer as a Pandas DataFrame, you should put your feature layer's name.
Then I have sorted by scale value, which you should put the name of the column which you want to sort the dataframe, and then create a new column which is accumaled values of size column which you should put yours.
If need more info please let me know.
Hope it works,
Best Wishes
Amir Sarrafzadeh Arasi
itayroei
thank you Amir
i will try your solution in sundey and let you knew if it's work for me
good weekend
itay
