Calculate Field with Python
1612
02-25-2022 02:04 AM
KalSsin
def abbreviate(x):
words = x.split()
letters = [word[:3] for word in words]
return "".join(letters)
I want to make it like the picture below.
What should I do?
Thank You~~
DuncanHornby
MVP Notable Contributor
A solution is this:
def abbreviate(x):
    words = x.split()
    letters = [word[:3] + " / " for word in words]
    text = "".join(letters)
    text = text[:-3] # Remove last slash
    return text
DuncanHornby
A solution is this:
def abbreviate(x):
    words = x.split()
    return text
KalSsin
It's incredible.~~~~
Thank you so m~~~~uch.
JayantaPoddar
MVP Alum
Just the following expression should work. No Code Block required.
'/'.join([i[0:3] for i in !Name_Add1!.split(' ')])
Think Location
