Calculate Field from related table
2893
6
02-16-2023 01:28 PM
janderson_ksninc
I have a table of points from field observations and a related table holding the pictures for each point. I need to rename the photos after the ID of the point. I would like to take the value from the ID field of the points and use it to replace the attachment name, then concatenate a ".jpg" and the end of the string. Is there an Arcade Expression that does this?
RhettZufelt
MVP Notable Contributor
Not sure of a way in Arcade, but very doable in python.
I use this on feature class with attachments enabled to update the attachment name to the id of the point (My attachments are all jpegs).
import arcpy
inFeatureClass = r'Database Connections\dbname.sde\dbname.DBO.Points'         # feature class with attachments
pointFieldsList = ['GlobalID','ID']                                           # fields to load into cursor
inTable = r'Database Connections\dbname.sde\dbname.DBO.Points__ATTACH'        #  attachment table for feature class
tableFieldsList = ['REL_GLOBALID', 'DATA', 'ATT_NAME', 'ATTACHMENTID']        # field list in attachment table
global_dict = {}
with arcpy.da.SearchCursor(inFeatureClass, pointFieldsList) as point_cursor:  # cursor to make dict of globalID's
        for row in point_cursor:
          if row[1]:
            row1 = row[1]                                 # I'm using "ID" as my name field, but is
          else:                                           # not always populated.  if Null, substitute "NA"
            row1 = "NA"
          global_dict[row[0]] = row1                      # add to dict with globallID as key, name as value
with arcpy.da.UpdateCursor(inTable, tableFieldsList) as cursor:
    for row in cursor:
        if row[0] in global_dict:
            row[2] = global_dict[row[0]] + '.jpg'
            cursor.updateRow(row)
R_
JohannesLindner
For the Calculate Field tool with Arcade:
var related = First(FeaturesetByRelationshipName($feature, "TestPoints__ATTACHREL"))
if(related == null) { return $feature.ATT_NAME }
return related.OBJECTID + ".jpg"
Before:
After:
Have a great day!
Johannes
janderson_ksninc
Thanks for responding! Would you happen to know how to do this in an Arcade Expression for an indicator in Dashboards?
JohannesLindner
What do you want to show in the indicator?
Have a great day!
Johannes
TarkingtonGeospatial
I know I'm resurrecting an old post, but whenever I use FeatureSetByRelationshipName I get an "Invalid Relationship name" error. I know the name of the relationship is corrected and the relted worked correctly because I can see the data in the pop up.
Would you happen to have any insight on how to fix this?
NourSalamJMT
@JohannesLindner very slick way of solving my problem. Thank you for sharing!
