Caching Derived Mosaic Dataset
808
08-16-2024 06:23 AM
beele
Dear all,
I created a derived mosaic dataset, plus its overviews. The derived mosaic dataset is correctly displayed in ArcGIS Pro, all the parameters seem set correctly. After, I published it as a Web Layer. During the publishing step, I used the Option "Cache manually on the server" because I only wanted to cache specific levels later.
After this step, I used the "Manage Map Server Cache Tiles" tool to generate the cached levels I need.
I don't understand why but one of the mosaic datasets I added recently to the derived mosaic dataset is not cached like the others. I tried multiple times to republish the Web Layer and regenerate the cache but it doesn't work. Also, I tried to modify this parameter "Maximum number of raster per mosaic" for that specific mosaic dataset (https://pro.arcgis.com/en/pro-app/latest/help/sharing/analyzer-warning-messages/24062-a-higher-value...).
Am I missing any step?
Thank you in advance for your help.
