BUG: ArcGIS Pro 3.6 cannot create a project package if there is a georeferenced PDF on a Map
1177
12-19-2025 08:51 AM
scanasm
ArcGIS Pro 3.6 cannot create a project package if georeferenced PDFs are opened on a map, even when placed as attachments and saved in a folder within the project. The project package fails to package with the generic error "general function failure".
If the PDFs are removed from the map, the project is packaged normally. I tried all options for packaging locally or uploading to ArcGIS Online, sharing within or outside the organization, with/without toolboxes, and with/without only valid history items. Grouping or ungrouping the PDFs in the map, removing their transparencies, and everything fails.
The workaround is adding the PDFs only as attachments to the project package and asking the recipient to add them to the map after unpacking. However, the expected behaviour would be that ArcGIS Pro could package a project that has maps with georeferenced PDFs. Has anyone experienced a similar behaviour? Are there any active BUGs for this issue?
Sam
Tags (1)
DanPatterson
MVP Esteemed Contributor
None on the public facing support site.  You should report it since it may not be specific to your case but part of a broader project packaging issue
... sort of retired...
Andrew--Johnson
Hi Sam,
I was able to reproduce the error you are seeing. I'll log an internal bug with our packaging team to investigate this. I'll follow up once I have some more information.
thanks,
Andrew
Andrew--Johnson
Hi Sam,
I just wanted to update you that the packaging team has fixed this bug for the next release of ArcGIS Pro. Tentative release date will be in May.
thanks,
Andrew
