Buffer Wizard
4982
8
12-10-2020 12:42 PM
SarahHartholt
Just wondering if the Buffer Wizard is available in ArcGIS Pro - a quick google search didn't turn anything up. I like the ability to save the buffer in an existing editable layer rather than creating a new feature class when I need to run multiple iterations.
Tags (1)
Scott_Harris
The Buffer tool found on the Modify Features pane (Edit ribbon) allows you to output the tool's results to an existing "editable" layer.
https://pro.arcgis.com/en/pro-app/help/editing/create-a-2d-or-3d-buffer.htm
Robert_LeClair
Esri Esteemed Contributor
Sarah - I know exactly what you're talking about and used this in my pre-Esri days.  I looked at the internals as well as ArcGIS Ideas and don't see anything about this.  I'd recommend you create a new ArcGIS Idea for this so it gets on the radar for ArcGIS Pro equivalency.
SarahHartholt
thank you! I'll submit it as an ArcGIS Idea
Scott_Harris
Robert_LeClair
Aha!  That's awesome!  I was not aware of that - today I learned!  Thx Scott!
DanPatterson
MVP Esteemed Contributor
It never gained much traction...
Bring back the Buffer Wizard - GeoNet, The Esri Community
... sort of retired...
JamesEddy
The Buffer Wizard is on the Analysis Ribbon in ArcGIS Pro.
efavs
If you want a buffer to be drawn inside a polygon, used the Buffer analysis tool, and specify a negitive number in the "Distance" field.
efavs
Not sure if you've found a work-around, but if you want a buffer to be drawn inside a polygon, used the Buffer analysis tool, and specify a negitive number in the "Distance" field.
