Buffer tool: Geographic Input using Linear units set to Planat creates a geodesic buffer
819
11-11-2025 06:15 AM
Craig_Eissler_Iceman
Using the Buffer tool, if the Input layer is in Geographic Coordinates, you set the Buffer Distance to a Linear unit (Feet, Miles, etc.), and the Measurement Method to Planar, ...Geodesic Buffers are created automatically.
Q: If that's the case, why isn't the 'Planar' option grayed-out and just force you to use the 'Geodesic' option?
Thanks, CCE
Priya_Das
Hi @Craig_Eissler_Iceman
The Planar option is the default. This option will automatically determine the method to use based on the coordinate system of the input.
Documentation: https://pro.arcgis.com/en/pro-app/latest/tool-reference/analysis/buffer.htm
Thanks, yes, I've already read the Help doc, which is what prompted my question. I'll re-post below:
"Why isn't the 'Planar' option grayed-out and just force you to use the 'Geodesic' option?"
