Broken bookmarks in Arc Pro
2531
02-10-2025 12:05 PM
MichaelMorgan4
In Arc Pro 3.3: I have a project that basically serves as my address management and dispatch data update project. My main map in this project is called "Addresses". I have several bookmarks created in this map representing different cities and unincorporated areas, and now most of these are "broken", i.e. they do not have a label, will not zoom or pan to their areas, and cannot even be deleted or reset. Bookmarks for other maps in the same project seem to work as normal. Is there some other way to get into the project file and remove the broken bookmarks?
I left a screen shot of what these bookmarks look like from the standard Map -> Bookmarks menu in Arc Pro.
DavidPike
MVP Notable Contributor
I'm guessing the manage bookmarks option isn't working.
First I'd save a new copy of your APRX for this:
If you open the APRX using winzip or 7zip etc you have a folder called 'map'.  Inside there, the 'map.xml' seems to store the bookmark config.
I'd edit/delete what you need from there (When doing this, I would compare the map.xml from another working project with bookmarks to avoid any formatting mistakes or deletions).
I've not tried this and it's likely not recommended, and also again - do it on a completely isolated copy of your original, and backup the map.xml just-in-case anyway.
MichaelMorgan4
In the .aprx Map folder, there are several .json and .xml files. So far, none of them seem to have any reference to "bookmark". I had opened 3 files with a name "map": Map.json, map2.xml, and map3.json.
imansbburg
I too am seeing this same issue after having installed the latest patch for pro 3.4.2.
Mark_Eygenhuysen
This happened to me in ArcGIS Pro 3.5.2, I have a number of bookmarks that went "blank", do not function, cannot be edited, cannot be removed.  Is there anything I can do aside from messing with files I shouldn't mess with?  My coworkers told me my mistake was to upgrade to 3.5.2 & I should go back to 3.4 because of all the bugs in 3.5.x releases.  The "Technical Support" link is also broken, including the link in the message to "contact our support team".  How embarrassing is that?  Certainly more time-consuming and problematic than advertised!
DmytroLukash
I encountered this issue in version 3.6.1 (as of 2026).
The easiest workaround I've found is to manually edit the map configuration. Here is the step-by-step process:
  1. Export/Save the map as a .mapx file (which uses the JSON format).
  2. Open the file in any text editor and locate the "bookmarks" key. It should contain a list of elements.
  3. Clear the list so it becomes empty ([]), or retain only the specific bookmarks you actually need.
  4. Save the .mapx file and import it back into your project.
