Bring in Layers Not Visible By Default in Pro
2208
01-31-2017 08:47 AM
MichaelVolz
Esteemed Contributor
When using ArcMap and adding large feature classes to the document, I have ArcMap setup so that layers are not visible by default as it could take over a minute or two to refresh the map.  This is setup with
Customize->ArcMap Options->General  Make newly added layers visible by default (unchecked)
Does this same functionality exist in Pro?
If so, can someone show me how this can be setup?
AdamZiegler1
Hi Mike - Here's what you're looking for I believe. Under Project --> Options --> Map and Scene
-Adam Z
AdamZiegler1
-Adam Z
MichaelVolz
Thanks for the quick reply as that was exactly what I was looking for.
