Batching in ArcGIS Pro
3730
11-12-2019 11:47 AM
GrantSmith
Is there a way to batch in ArcGIS Pro that is similar to the way batching is performed in ArcMap/Catalog currently? I would like to batch the Feature Compare tool to compare "old" versions of data to "new" versions and detect changes between them (row counts, attribution changes, etc.). In ArcMap, it's as easy as right clicking the tool, selecting "Batch", then dragging and dropping the inputs (picture attached).  When I perform the same process in Pro, I am only allowed to select 1 parameter to batch with (i.e. I can only have multiple inputs for Test Features or Base Features, not both).
Another way to put the question could be: is there any way in ArcGIS Pro to run a batch tool with more than 1 batch parameter?
Thanks for any help!
KoryKramer
Esri Esteemed Contributor
This is an equivalency issue over on ArcGIS Ideas‌ https://community.esri.com/ideas/15547 You can go there to up vote and add your use case.
Thank you.
KoryKramer
Thank you.
