Basemap loading when adding polygon into a scene.
780
01-04-2023 02:23 PM
johnhartniles
I created a polygon feature that displays just fine in ArcGIS Pro in the Map view. When I copy or load the polygon into the Local Scene, it also displays a hillshade model.
If I create a new scene and then add the polygon, the hillshade model does not display.
What is going on here??
Taren_Esri
Hi @johnhartniles
What if you add the polygon, then manually go to the Map tab, then Basemap, and select the Topographic map option?
