Autopopulate a field where it is an alpha-numeric entry but each item needs a unique "number"
1892
12-05-2022 07:57 AM
MartyLoper
I have multiple features that required unique names they are all required to carry both alpha and numeric characters.  How can I autopopulate the feature "name"?
Example of the names:
WD-F02-01
WD-F02-02
WD-F02-03 and so on.
AyanPalit
@MartyLoper This is very common scenario and has multiple solution options depending on requirements and maintenance preference.
Ayan Palit | Principal Consultant Esri
Aaron_J_Gutierrez
HI Marty did you find a solution to this? Im having the same issue and wondering how you solved it
