Automate layout design
1521
09-06-2022 06:29 AM
Annie0308
I have 100 different layouts, each zoomed to different polygons on the map. I would like to add two accompanying images, that are unique to each layout and positioned as shown in the screenshot below.
Is there a way to automate the process of adding, resizing and positioning the two images and my map frame as presented in my screenshot for each unique layout? It is currently very time consuming to do so for all 100 layouts..
I would also like to export all 100 layouts into jpegs at once. Currently I have to manually export each layout one by one.
wayfaringrob
Honored Contributor
Hi there,
Have you looked into the map series functionality? That would help automate some of the layout process; inserting custom images for each bookmark/feature, I'm not sure about.
Map series—ArcGIS Pro | Documentation
wayfaringrob
Honored Contributor
I'm seeing near the bottom of this page that dynamic pictures are a thing. Sounds like you'll just need well-structured file names, and in my mind, that's worth the effort. Rather than manually placing them all (and manually fixing anything that changes), it may be easier to just dump them all in one folder with a predictable name based on the feature. Spatial map series and dynamic elements—ArcGIS Pro | Documentation
