Attribute table blank after exporting from successful table join in ArcGIS Pro
8988
10
02-26-2020 02:54 PM
KathrynAngleton
I did a table join in ArcGIS Pro of ACS Tiger data to block groups, turned off the fields I didn't want to keep, and exported the layer as a feature class in a gdb, then as a shapefile outside the gdb and both yielded blank attribute tables. Any idea why exporting keeps the fields but drops all the records?
DanPatterson_Retired
looks like they are for different areas within the featureclass and that '0' is a valid observation.  Any chance that you sorted on a column or something?  maybe the 0's will reappear if you do which means the data and join were fine yesterday
