Attribute Rule
795
11-09-2020 06:59 AM
MarlaJohnson
I set up attribute rules in ArcGIS pro and now the data will not open in ArcMap. Has anyone experience this issue?
JoeBorgione
That is expected behavior.
Introduction to attribute rules—ArcGIS Pro | Documentation
Adding attribute rules to a dataset impacts backward compatibility:
  • Once attribute rules are added to a dataset, it is incompatible with ArcMap or ArcGIS Pro 2.0 and earlier. See Client and geodatabase compatibility for more information on functionality available when using mixed client and geodatabase releases.
