Attribute not set to NULL in python script using UpdateCursor
1635
12-08-2025 11:15 AM
LoriEmersonKDOT
When I set a field to None in an arcpy script, it shows as None in the attribute table rather than <Null> when using an UpdateCursor.  Why does it set it to a text value of "None" rather than <Null>?
# Loop through NEW to OLD spatial join results
#     If attributes don't match, then show the differences in the
#     new Changes_ attribute fields.
with arcpy.da.UpdateCursor(
    fc, fields, where_clause = "Join_Count=1"
) as cursor:
    for row in cursor:
        myADDR = ""
        #Compare L_F_ADD = L_F_ADD_1 and L_T_ADD = L_T_ADD_1 and R_F_ADD = R_F_ADD_1 and R_T_ADD = R_T_ADD_1
        if row[4] != row[24]:
            myADDR += "L_F_ADD (new = old): " + str(row[4]) + "=" + str(row[24]) + " | "
        if row[5] != row[25]:
            myADDR += "L_T_ADD (new = old): " + str(row[5]) + "=" + str(row[25]) + " | "
        if row[6] != row[26]:
            myADDR += "R_F_ADD (new = old): " + str(row[6]) + "=" + str(row[26]) + " | "
        if row[7] != row[27]:
            myADDR += "R_T_ADD (new = old): " + str(row[7]) + "=" + str(row[27]) + " | "
        if myADDR == "":
            myADDR = None
        row[43] = myADDR
        cursor.updateRow(row)
Tags (3)
LoriEmersonKDOT
I fixed the problem by removing the Default of None when adding the field to the existing feature class attribute table.  Now the python assignment of None works when performing the updateRow within the UpdateCursor.UpdateCursorDefaultValue.pngUpdateCursorDefaultValue.png
DanPatterson
MVP Esteemed Contributor
is it a featureclass in a geodatabase that you are tryig to update? or a shapefile? (which doesn't support null
... sort of retired...
JoshuaBixby
In this case, i.e., trying to NULL a shape file field that doesn't know/support NULL, the DA update cursor will generate a RuntimeError instead of populating the field with "None":
  File "<string>", line 4, in <module>
RuntimeError: The field is not nullable. [TXT_FLD]
LoriEmersonKDOT
Hi Dan,
It's a feature class in a file geodatabase.  I even set the Default value to NULL (None) when adding the new field, so I know it accepts nulls.
LoriEmersonKDOT
AlfredBaldenweck
MVP Frequent Contributor
That's super odd. Do you have the same problem with a different table?
