Assigning the nearest raster elements to a point
2345
06-10-2020 06:34 AM
StefanJodl
Hello,
I have a feature class containing points on a map and several raster files with a resolution of 250mx250m. I want to assign each raster element to the nearest point. So far I have tried using euclidian allocation, but this didn't work out as i planned.
Does anyone have a solution for this problem?
Robert_LeClair
Esri Esteemed Contributor
One workflow that I can think that could work is:
  1. Run the Raster to Point geoprocessing tool first to create a point feature class with the VALUE you wish to extract from the raster to the point attribute table.
  2. Then run the Spatial Join geoprocessing tool with the CLOSEST match_option parameter.  The target_features is your current point feature class and join_features is your output feature class from Step 1.
Hope this helps!
