artifact left after geoprocessing
1037
11-20-2019 01:47 PM
CharlottePeters2
I did some geoprocessing editing in AGP v. 2.4.2, like clipping one feature against another feature in the same feature class. After the clipping is successful, there is a copy of the feature left in map that is not part of any dataset. I cannot select the artifact to delete it. Refreshing the map does not delete it. I have to delete the dataset, refresh the map, and add the dataset back into the project.
Is this a AGP bug or is there a setting I can change?
by Anonymous User
Not applicable
Hi Charlotte,
Can you provide some more details on the full workflow/steps you took that arrived at this result and where this feature is stored (file gdb, ent gdb, hosted or ArcGIS Server feature layer etc.)?
I am unable to reproduce this with my own data and would like to understand more about the data and workflow.
Best,
Aaron
