Arcpy parameter for ArcGIS Pro Document
5721
6
03-22-2021 12:24 PM
Labels (3)
KennethEggering1
Is there a way to specify a Pro-Doc as a parameter input to a Python Toolbox? I'm writing a tool that iterates over different layouts, and exports to PDF. It would be nice to allow users of the tool the ability to specify a ProDoc (e.g. "//file/path/prodoc.aprx" or "current"). It seems that arcpy for Pro has not been updated, as it still has an ArcMap option (dataType="DEMapDocument").
KennethEggering1
Perhaps not the most elegant solution, but here is what I went with in the end. Any comments or suggestions greatly appreciated.
# -*- coding: utf-8 -*-
import arcpy, os
class Toolbox(object):
    def __init__(self):
        """Define the toolbox (the name of the toolbox is the name of the .pyt file)."""
        self.label = "Toolbox"
        self.alias = ""
        # List of tool classes associated with this toolbox
        self.tools = [Tool]
class Tool(object):
    def __init__(self):
        """Define the tool (tool name is the name of the class)."""
        self.label = "Tool"
        self.description = ""
        self.canRunInBackground = False
    currentList = ["CURRENT", "current"]
    def getParameterInfo(self):
        """Define parameter definitions"""
        param0 = arcpy.Parameter(displayName="Pro-Document",
                                 name="proDocument",
                                 datatype="GPString",
                                 parameterType="Required",
                                 direction="Input")
        param1 = arcpy.Parameter(displayName="Layout",
                                 name="inlayout",
                                 direction="Input")
        params = [param0, param1]
        return params
    def isLicensed(self):
        """Set whether tool is licensed to execute."""
        return True
    def updateParameters(self, parameters):
        """Modify the values and properties of parameters before internal
        validation is performed.  This method is called whenever a
        parameter has been changed."""
        if parameters[0].value:
            p0Val = parameters[0].valueAsText
            if (p0Val.endswith(".aprx") and os.path.exists(p0Val)) or p0Val in self.currentList:
                aprx = arcpy.mp.ArcGISProject(parameters[0].valueAsText)
                layout_list = [l.name for l in aprx.listLayouts()]
                parameters[1].filter.list = layout_list
        return parameters
    def updateMessages(self, parameters):
        """Modify the messages created by internal validation for each tool parameter.
        This method is called after internal validation."""
            if not ((p0Val.endswith(".aprx") and os.path.exists(p0Val)) or p0Val in self.currentList):
                parameters[0].setErrorMessage("Not a valid ArcPro Document")
        return
    def execute(self, parameters, messages):
        """The source code of the tool."""
        arpxPath = str(os.path.normpath(aprx.filePath))
        arcpy.AddMessage(f"Pro-Doc Path: {arpxPath}")
        return
The main limitation is that the "Pro-Document" input parameter does not have the nifty folder icon (see red arrow) for users to click and navigate to the document. Users have to build/write a path string if not using "current."
nita14
Why not to specify File as Data Type with .aprx extension? Does it work for you?
BR,
Adam
KennethEggering1
Datatypes of "DEFile" and "GPString" can both work with limitations. Each allow users to enter errant inputs (e.g. .txt files, or random strings), which throws an error on subsequent parameter inputs that build off it. Easily enough for users to figure out I suppose. Would still be nice if ESRI added an ArcPro datatype, allowing users to open the folder icon pre-filtered with only .aprx files.
Luke_Pinner
MVP Regular Contributor
Perhaps use DEFile and only allow aprx files using a filter:
        displayName="Input Project",
        name="in_project",
        datatype="DEFile",
        direction="Input")
    #  set the filter list to a list of file extension names
    param0.filter.list = ['aprx']
KennethEggering1
Thanks for the tip @Luke_Pinner. The tool needed to be able to work in the "current" pro-document, so filtering by the aprx file extension didn't fully work for this situation. I opted to go with a parameter type of GPString and trap any errors in the updateParameters/updateMessages below.
KennethEggering1
import arcpy, os
    def __init__(self):
        self.alias = ""
        self.tools = [Tool]
class Tool(object):
    def __init__(self):
        self.label = "Tool"
                                 name="proDocument",
                                 direction="Input")
                                 name="inlayout",
                                 direction="Input")
        return params
        return True
        return parameters
        return
        return
Luke_Pinner
One suggestion is to use 2 parameters, one a DEFile and the other GPBoolean. Have parameter validation set to clear one when the other is altered. Something like:
import arcpy, os
    def __init__(self):
        self.alias = ""
        self.tools = [Tool]
class Tool(object):
    def __init__(self):
        self.label = "Tool"
        param0 = arcpy.Parameter(displayName="Current Pro-Document",
                                 name="currentProDocument",
                                 datatype="GPBoolean",
                                 parameterType="Optional",
                                 direction="Input")
        param1 = arcpy.Parameter(displayName="Other Pro-Document",
                                 name="otherProDocument",
                                 datatype="DEFile",
                                 direction="Input")
        param1.filter.list = ['aprx']
        param2 = arcpy.Parameter(displayName="Layout",
                                 name="inlayout",
                                 direction="Input")
        params = [param0, param1, param2]
        return params
        return True
        if parameters[1].altered and not parameters[1].hasBeenValidated:
            parameters[0].value = False
            parameters[2].value = None
            parameters[2].filter.list = []
            prodoc = parameters[1].valueAsText
        elif parameters[0].value and parameters[0].altered and not parameters[0].hasBeenValidated:
            parameters[1].value = None
            prodoc = 'CURRENT'
        else:
            prodoc = None
        if prodoc is not None:
            aprx = arcpy.mp.ArcGISProject(prodoc)
            parameters[2].filter.list = layout_list
        return parameters
        return
