arcpy.management.Copy to In Memory Error
2645
6
09-10-2024 06:25 PM
Bryan_bsc
Does anyone know if  arcpy.management.Copy is meant to be the same as arcpy.CopyFeatures_management? It appears to be the same unless I use it to copy features to memory in which case it gives the following error.
ERROR 000979: Cannot copy between different workspaces.
Example code is below:
fc = r"gisdata.sde\GIS.GISDATA.assets\GIS.GISDATA.plots"
arcpy.CopyFeatures_management( fc, r"memory/in_memory_temp_file") # This works with no errors
arcpy.management.Copy( fc, r"memory/in_memory_temp_file") # This gives the error above
Any help would be appreciated.
Thank-you!
DanPatterson
MVP Esteemed Contributor
interesting, sounds like a variant of...
BUG-000167752 for ArcGIS Pro (esri.com)
... sort of retired...
MobiusSnake
MVP Regular Contributor
I believe the Copy tool is the geoprocessing version of a catalog copy/paste operation, and copy/paste doesn't support going from a geodatabase workspace to a non-geodatabase workspace.
DougBrowning
Well why not?  So weird
MobiusSnake
I can only speculate, maybe it's because it's "lossy"?  You lose attachments, relationships, that kind of thing, so you have to use a tool from the conversion toolbox instead.
DougBrowning
I have for sure seen that memory is not a full GDB.  For example certain SQL functions do not work.  Not documented anywhere that I have found so its a hunt and peck which can drive you nuts.
MobiusSnake
Yup, even very basic GDB stuff like domains aren't supported if I remember correctly.
